swap for HD rear end
Old Dec 6, 2007 | 08:36 AM
  #11
gunmetalsilvy's Avatar
Default RE: swap for HD rear end
Ok so i just looked at a few wrecker websites and i found one for $1200USD. My answer was **** that. So i hear good things about eaton and detroit lockers, anyone have opinions? I'm not going to install the diff. myself because by the sounds of it they're really easy to screw up and better left to a professional.
For those who have got their differentials swapped to lockers what did you pay for parts and labour? What ratio did you get? I'm thinking of going with the 4.10, how bad would the MPG get hit?
Cheers
Old Dec 6, 2007 | 08:44 AM
  #12
04BLKCHEVY's Avatar
Well you have the 2wd and u shouldnt have any problems with getting any gear ratio. Just depending on the eyar of your truck you can easily swap the rear axel with a z71 axel from the same year. Hardest part of changing the axel is how heavy they are. They do make kits to go from 8 to 6 lug but your better off getting a axel from the same year Z71. If you change axels yourself it would be cheaper than taking your truck to get the gears changed.
Old Dec 6, 2007 | 11:16 AM
  #13
01hd's Avatar
I would leave the gear ratio the same & just install a mecanical locker or limited slip. On a street driven truck you wouldn't want a selectable locker in the rear ( ARB, E-Trac...).
Old Dec 6, 2007 | 12:10 PM
  #14
awesome, i'm going to shop around some more for an axle at the wreckers because i really don'twant to pay for the labour to change just the diff.
thanks everyone, i'll post any progress.
if anyone still has advice or info it'd be much appreciated
Justin
Old Dec 6, 2007 | 03:04 PM
  #15
Cracker's Avatar
http://www.usedpartslive.com/live/1/.../Differential/
This site may be useful to find something local.
Old Dec 6, 2007 | 07:40 PM
  #16
smoke20's Avatar
The labor will be around $300-$500 to install the locker, and $1000 to install the new gears (parts and labor). Together you would save on the labor some and get gears and locker for $1000 plus cost of the locker.
And you are right, don't do it yourself.
Old Dec 6, 2007 | 07:42 PM
  #17
Cracker's Avatar
Gun - where are you?
Old Dec 13, 2007 | 08:21 AM
  #18
Sorry about the late reply,
I'm from Ontario. Haven't had any time to look for an axle yet.
- Justin
trev0006
Feb 13, 2013 09:01 AM
Birdable67
Nov 2, 2009 11:22 PM
ABSPUD
Jul 18, 2009 03:59 AM
89cheyenne
May 25, 2009 01:24 AM
repotime
Sep 26, 2008 11:48 AM
