TBS Spacer whistle
Old Jan 30, 2008 | 03:51 PM
bad2006z71's Avatar
Default TBS Spacer whistle
ok ive owned the jet and helix power tower tbs spacers. with my K&N 63 series cai, the jet sounded like a turbo, and the helix just had a slight whistle throughout the throttle range. the thing is i hate the whistle but enjoyed the throttle reponse (didnt have them on long enough for mpg test)
my question is, the Trans-Dept tbs spacers i keep reading about on here, does either the helix style or smooth bore whistle at all (with a CAI) and which one do you guys seem to like better?
thanks for the help
Old Jan 30, 2008 | 04:07 PM
stopspazinout's Avatar
Default RE: TBS Spacer whistle
any of the smooth bore spacers are not going to whistle, its that spiral that creates the whistle. which seems to be more audible with a CAI then a stock one. if you dont want the whistle but want some response a smooth bore is what your looking for.
Old Jan 30, 2008 | 04:22 PM
hunt4game29's Avatar
I think i have the smooth bore and its for trans-dept. And it whistles just lightly really with my exhaust and anytype of music playing i cant hear it at all.
Old Jan 30, 2008 | 05:01 PM
bad2006z71's Avatar
thanks guys, now i read something about this but i was a little confused, does the smooth bore produce the same results (ex. better mpg, throttle response, hp) as the spiral tbs?
Old Jan 30, 2008 | 06:01 PM
72charger's Avatar
I have Trans Dapt's torque curve spacer and it doesn't whistle. Great gains too! Was $62 to my doorstep from Summitracing.com . Trans Dapt engineers their spacers to not whistle but still be as affective.
Old Jan 30, 2008 | 06:40 PM
bad2006z71's Avatar
72Charger:
do you have a CAI or just a stock intake? again just curious with the whistling
i enjoyed the helix power tower on my 89 k5 with the tbi (of course 2 different fuel injection systems here)
my friend also had good mpg gains from his 93 silverado with the tbi 350.
thanks for the replies.
Old Jan 30, 2008 | 10:37 PM
72charger's Avatar
No I have the factory intake setup + K&N air filter + redneck ram air mod. Ofcourse you get the sucking sound from a good intake but you still should not here any whistle from the TBS with a Trans Dapt. It's just designed not to do that. Go on www.summitracing.comand do a search for trans dapt tbs' for your truck and read the descriptions of them to make up your mind about them. They advertise the torque curve as being a bit better than the smooth bore but that may just be an advertising gimmick... who knows.
Old Jan 30, 2008 | 10:43 PM
skobiak's Avatar
On the subject of TBS's, anyone know why they don't reccomend using one with a CAI? I have Jeg's TBS and it said "not for use with FIPK type air intake"......
Old Jan 30, 2008 | 11:43 PM
72charger's Avatar
Because it relocates the intake into the fan shroud basically. In most cases however, you can trim the fan shroud and be okay. A lot of people on here have both. A few people in the past have complained that it actually put the intake into the fan and they had to trim the FIPK tube a bit to move it forward away from it. Either way it is doable.
joduranken
May 28, 2011 01:33 PM
bretchevfarm1
Jan 9, 2011 02:40 AM
islandlure31
Nov 4, 2009 08:48 AM
78chev2bnice
9
Jul 24, 2007 10:19 PM
careflitemedic
Aug 26, 2006 03:11 PM
