Temperature Gauge
I guess I am a little late but what you described is typical fan clutch failure. At an idle your motor isn't turning high RPM's so the clutch is able to still move some air. When you accelerate the clutch basically slips and moves less air than when idling. I wouldn't worry about an electric fan. Just replace that factory clutch. You will probably need to rent a fan clutch removal tool from your local auto parts store if you don't have one. I know the stores around here basically rent it for free (you pay for it and bring it back and they give you a full refund).
I found out the fan clutch is pretty much not working. Is a fan clutch easy to replace?? A mechanic told me to switch to an electric fan. is it worth the change??
Hello, I am new to this forum and I know this is an old thread, but I was wandering if you ever found the problem. My 1998 K2500 is doing the same thing. I just changed the thermostat (195 deg) and the same thing happens.
Mazzella
Oct 28, 2021 10:15 AM
sierra94
11
Apr 13, 2011 11:43 AM
1993GMCSierra
Jun 28, 2009 09:31 PM
conjohncept
Jan 8, 2009 06:10 PM
