Torsion key lift ride change?
Old Feb 7, 2009 | 11:24 PM
silverado17's Avatar
Default Torsion key lift ride change?
I am thinking about doing a torsion key lift on my 03 silverado quadcab. I was wondering if this will effect my ride in any way as far as stiffness or anything. Thanks
Old Feb 9, 2009 | 09:49 AM
bfg112's Avatar
Default RE: Torsion key lift ride change?
Somebody correct me if I'm wrong here. Whe you crank the torsion keys you add more preload to the torsion bar, so when you set the truck back down the suspension doesn't sag as much, making it sit higher. I would then have to assume that cranking the torsion keys will make the ride stiffer.
Old Feb 9, 2009 | 12:59 PM
ahcapone's Avatar
Form my experience, it will make your ride stiffer. The torsion bars won't let the shocks work as much because they will make the "bottom out" point higher.
dukesbb37
Aug 30, 2011 11:08 AM
6mins2live
32
Sep 2, 2009 04:51 PM
silverado17
Feb 7, 2009 11:31 PM
djz28
Feb 3, 2008 03:01 PM
Tonyvt
Dec 4, 2007 07:35 AM
