trailer brake
Old Sep 14, 2006 | 10:08 PM
jamesduke84's Avatar
Default trailer brake
I own a 98 silverado 5.0. I recently bought a Hopkins trailer brake and the instructions tell me to "simply splice onto the OE connector under the dash." I know the cluster is under the dash, but i have no idea which wires to splice into. I know which wires control what on the trailer brake itself, but i'm not sure which wires to splice into. Does anyone have a diagram or any advice on what to do or what to buy?
Thanks, Mel.
Old Sep 29, 2006 | 06:21 PM
lg_rebel's Avatar
Default RE: trailer brake
James, here's a list of the wires in the main harness under the steering column. It came from a remote starter instructions. I'd make sure and stay away from any wires that run into a yellow plug, since those are the airbag wires. I hope this helps. If not, just let me know and I'll try to help you more.
MODEL YEAR(S)
FULL SIZE PICKUP 1998 -
KEY T-HARNESS IMMOBILIZER
N/A GM-1 GM's PASSLOCK 2 ANTI-THEFT System, Requires 791 Bypass Module
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED (+) IGNITION SWITCH HARNESS
STARTER PURPLE (+) or YELLOW (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 PINK (+) IGNITION SWITCH HARNESS
IGNITION 2 WHITE (+) See NOTE *4 IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) BROWN (+) @ HEADLIGHT SWITCH
POWER LOCK LIGHT BLUE (TYPE C) See NOTE *1 IN EITHER DOOR BOOT
POWER UNLOCK WHITE (TYPE C) See NOTE *1 IN EITHER DOOR BOOT
LOCK MOTOR WIRE GRAY (+) IN DRIVERS DOOR HARNESS
DOOR TRIGGER PURPLE (-) @ HEADLIGHT SWITCH
DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires #775 Relay
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN BLACK (-) STEERING COLUMN HARNESS
TACH WHITE @ ECM, See NOTE *2
WAIT TO START LIGHT See NOTE *3
BRAKE WHITE (+) SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFT YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used) GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
jclick
Jan 9, 2013 08:04 PM
enys5000
Dec 30, 2008 08:54 PM
ccornetto
May 22, 2008 10:32 PM
dbrown29
Mar 29, 2008 03:04 PM
adampgasser
Mar 5, 2008 01:23 PM
