Tranfer Case Woes??
Old Nov 2, 2012 | 11:08 AM
bighorn1's Avatar
Question Tranfer Case Woes??
Gentlemen/Ladies,
New to the forum, looking for some of your expertise and/or opinions.
I am not nearly as mechanical as I'm sure lots of you are, but here goes...
1998, Sierra,K1500, 5.7L, auto tran
PROBLEM/CONCERN..
- 4 wheel drive engages but, in 4h it developes a "whine" similar to tread noise on pavement at about 20 mph. Even though it works, I think the noise is excessive and should be looked at. Any ideas?
Fluid level is good, and shows good color.
Could this have anything to do with the actuator? as it tends to "grind" a bit in and out of 4l, as well? Help??
Old Nov 2, 2012 | 06:56 PM
RustyFordLover's Avatar
Every four wheel drive Chevy I have ever seen has done that. The tires have to be perfectly matched to bring that to a minimum, so you can try rotating your tires or buying new ones to see if that helps. I never use my truck in 4wd on the road, nor off road unless I really have to, but by them its usually too late and I'm already stuck :P
Old Nov 5, 2012 | 09:25 AM
bighorn1's Avatar
Default Transfer case Woes?
Thanks for the info - appreciate it
Mr.Cale
Feb 18, 2010 02:03 PM
zimsilverado
May 1, 2008 07:33 PM
72charger
18
Apr 2, 2008 09:00 AM
ryanadvo
Jun 18, 2007 10:20 AM
toppint1
Oct 4, 2006 04:06 AM
