Tranny Help
Old May 2, 2009 | 10:23 PM
89ChevySilverado's Avatar
Member
Default Tranny Help
Would like to swap out the tranny in my 89 with one that has Overdrive...... Hard to do?? any tips?? or should i just scrap the idea??
Old May 3, 2009 | 05:15 AM
You could easily throw a 700R4 under there, remind me, what do you have now?
Old May 3, 2009 | 08:00 AM
It's not that hard, you will need a different length drive shaft. Most salvage yards have a pile of them though. Of course your dash will still only read as a 3 speed - there won't be an overdrive spot on the shifter. Where your "D" is will now be "OD".
Old May 3, 2009 | 10:20 AM
Member
My plans where to find a truck in the salvage yard that had a tranny with overdrive in it.... pull the tranny, linkage, and the gauge cluster in the cab... i would just have to keep the odometer some how for my state inspection/emissions requirements...
Old May 3, 2009 | 05:46 PM
Don't forget the drive shaft. You can easily swap the gear selection part of the new cluster into your cluster. Good luck and let us know how it turns out.
Old May 4, 2009 | 12:52 AM
chrisbmo2000's Avatar
ummm................I think you all forgot one VERY important peice of the "puzzle"........how to engauge OD.........this is almost always done by computer but.........you can rig a toggle switch to "turn on" the OD solinoid
Old May 4, 2009 | 06:56 AM
You won't need a toggle switch. It will be on overdrive when you move the shifter to "D". This will be a 700R4 so it will go into OD without all that. I did the same swap in an older Silverado and it worked perfect.
Old May 4, 2009 | 07:56 AM
thats right the 700r4 is a hyro shift not an electric shift.......my bad
bigkucks89
Jan 20, 2009 07:16 PM
ductape
Jun 25, 2008 07:43 AM
bluechev97
Oct 9, 2007 07:22 PM
SierraV8
Aug 14, 2006 05:50 PM
cody4x4
Jul 18, 2006 01:08 AM
