Tranny Problem - Internal Or Electronic? Or Hydraulic? Stumped!
Old Oct 27, 2010 | 09:59 PM
uhcoog1's Avatar
Default Tranny Problem - Internal Or Electronic? Or Hydraulic? Stumped!
I've got a 2007 GMC Sierra Classic Crew Cab 5.3 Z71. It's the 4l60e/4l70e. My transmission went out on me while driving the other night. I drove home in second.
When put in Drive or 3rd from a dead stop, the truck does not move. 1 & 2 both work from a dead stop.
When I accelerate through 1 & 2, I can manually shift to 3rd, and manually shift to D and get into overdrive. Upon deceleration below the speed range of 3 or 4, it once again acts like it is in neutral.
None of the gears are slipping. The shifts are like they were before the incident.
Any idea what's going on? What system is responsible for engaging 1st gear when the car is stopped and put in drive or 3rd?
Old Oct 29, 2010 | 09:01 AM
thebigcomfy's Avatar
if your transmission was having mechanical problems i doubt you would be able to manage the way you say you have been. try replacing fuses and resetting your ecu by disconnecting your battery for a while.
Old Oct 29, 2010 | 10:10 AM
chrisbmo2000's Avatar
This transmission is in what is called "limp mode". Limp Mode can be caused by several things.....mechanical failure, electrical failure, and the biggest one..........HEAT........I would have the computer scanned and make sure the tranny is not getting too hot
dansvs
Oct 7, 2013 06:22 PM
PLussier
Aug 14, 2010 07:53 AM
dannyboy11
Mar 11, 2010 07:56 PM
Toolman
Jan 13, 2008 06:07 PM
Chevy_5150
Mar 3, 2007 10:45 AM
