Trans Cooler
Old Mar 16, 2011 | 08:59 PM
  #11
ucrtwf's Avatar
Mr Shamrock,
What did you come up with? I'm in the same boat (no pun intended) with my 1500. I'm looking to get the trans cooler soon. I'd be real interested in which model and how you hooked it up.
Thanks in advance,
Tim
Old Mar 16, 2011 | 10:43 PM
  #12
Originally Posted by ucrtwf
Mr Shamrock,
Thanks in advance,
Tim
I actually sold the 1/2 ton and bought a 3/4 ton with the larger trans. and a factory cooler. Sorry.
Old Mar 17, 2011 | 02:24 AM
  #13
jvp's Avatar
jvp
Member
Hey, Shamrock before you spend your money look in front of your radiator to see if you already have a Trans-cooler. Also you stated you have been pulling a light load.
Have you noticed an increase in your water temp? Most likely not. If so, and you do not have already have a trans cooler Hayden work fine, I have used them in the past and they won't let you down. I do not know your maintenance schedule but you might want to consider changeing your radiator fluid, as this will help control temps.
I am pulling 6650 lbs. with stock trans cooler in an 05, 5.3 no problems.
If you have not changed your trans fluid, you may want to also consider this as further protection. 90+K and running fine, and I am getting ready to change my trans fluid, this will be the second change I have done on this truck. I find it cheaper than rebuilding the trans.
Good luck
jvp
Old Mar 20, 2011 | 09:20 PM
  #14
ucrtwf's Avatar
Ok, I ordered the Scangauge II, I'm ready to order a Tru-cool M7B (due to the built in cool weather bypass feature). My question is how you guys actually piped your aux cooler in. I would think it would be easiest to pipe the outie of the OEM cooler into the innie of the new aux cooler than use the OEM hose back to the trans. This way I would only have to splice put the fitting into the OEM cooler, and into the Innie of the new one. Does this sound right? Or do you guys splice into the OEM return line and run the lines back to the radiator area?
Thanks as always,
Tim
bad2006z71
21
Apr 9, 2012 09:12 AM
Niko
Oct 4, 2009 11:54 AM
popo
Sep 8, 2007 11:05 AM
lowtoyz2
Apr 24, 2007 07:13 PM
waytooevil
Oct 25, 2006 12:46 AM
