Valve Covers
Old Jan 3, 2010 | 01:13 PM
josh29j's Avatar
Default Valve Covers
I have a 1989 chevy with 350 tbi motor. Would like to put new valve covers on it to dress it up a bit. found a set from autozone that is centerbolt which is what i need. What do i need for the other two holes in the valve covers. I know a breather and of course the oil cap. is the other hole just another breather? Do they need to have the the hose connected to them that run to the throttle body area?
Old Jan 3, 2010 | 02:54 PM
RUFFNECK4LYFE's Avatar
Thats for the PCV valve.
Old Jan 3, 2010 | 03:37 PM
josh29j's Avatar
Both have a hose running to the throttle body area.. My question more less is do i need those hoses..will it mess with the computer.
Old Jan 3, 2010 | 10:52 PM
Oh not at all my friend. But!!! In the long run, those are there for a reason. They help prevent moisture build up inside your motor. They suck out the vapors created from the heat inside the motor. Otherwise next time you change the oil, you will see a lil bit of water comin out.
Old Jan 4, 2010 | 07:21 AM
josh29j's Avatar
okay thanks. Now i know for the one just get the pcv valve and place it in the correct grommet. Now what about the other hose. Should i buy a breather and connect the hose to that. Or ? the hose is 1/2 dia on the outside
Old Jan 4, 2010 | 03:40 PM
No you can buy a breather that just sits there in the grommet with no hose.
Old Jan 4, 2010 | 08:23 PM
josh29j's Avatar
if i want to connect both hoses..will two breather/pvc work
klr650goldwing
Feb 11, 2010 11:24 AM
chevyrules
Oct 17, 2007 07:47 PM
chevyrules
Oct 16, 2007 06:26 PM
chevyrules
Jul 5, 2007 04:34 PM
elkbanner
Nov 30, 2005 11:44 AM
