Water Pump??
Old Apr 10, 2010 | 03:03 PM
gmc newbie's Avatar
Default Water Pump??
I have a 95 GMC Sierra, 350 motor, and i am leaking coolant. Checked my oil for the "milkshake effect" to see if head gasket is gone. Oil is okay. Checked upper and lower hoses, both good. Coolant is coming down the front of my engine, running along the front of my oil pan, and onto the ground. Water pump is all I can figure, any suggestions?
Also checked the Haynes book, it suggested checking the weep hole, but I can't seem to locate it. Any info is welcomed. Thanks.
Old Apr 10, 2010 | 03:46 PM
Worf's Avatar
The weep hole is a small little hole that is under the water pump shaft. You may have a bad seal. Water pump seals wear out after a while.
Here please see the below thread.
https://www.truckforums.com/forum/sh...ad.php?t=13463
Old Apr 11, 2010 | 08:44 AM
acnas's Avatar
Lower intake gasket!
Old Apr 11, 2010 | 08:47 AM
A 95 is still TBI and only has an intake gasket from the intake to the heads. It is a possibility though. They did not have the issue like the 96-99 Vortec motors however. Check to see how high the leak is coming from. My money is on the water pump...but what do I know?
Old Apr 11, 2010 | 10:02 AM
chrisbmo2000's Avatar
My vote is on the water pump
Old Apr 12, 2010 | 05:52 AM
aja72's Avatar
Banned
Read this :- www[.]howstuffworks[.]com[/]cooling-system[.]htm/printable
Here is detail information about how the cooling system is work. I hope you will find solution of your problem after read this.
Old Apr 12, 2010 | 06:31 PM
gmc newbie's Avatar
Changed the water pump today (and removed about 3 layers of skin off my knuckles ) and that seemed to fix it. No leaks happening anymore(for now), thanks to all who replied to my post.
Thanks again!!
Old Apr 13, 2010 | 05:01 PM
Worf's Avatar
I am glad we could help
In2Trux
Apr 19, 2015 08:50 PM
scauntay
13
Dec 31, 2006 03:31 AM
no fear
Jul 10, 2006 09:57 PM
KS Z71
Jan 27, 2006 04:19 AM
ardvaark
Jul 11, 2005 06:12 PM
