What would cause my fuel gauge to read empty when it is full?
Old Nov 9, 2009 | 07:49 PM
K3500dump's Avatar
Default What would cause my fuel gauge to read empty when it is full?
2001 Chevy Silverado 3500 1 ton dump
Duel tanks one relay for pumps both tanks have FSU .
What I have done :
I have problem with the second tank pump not pumping for some reason. I know this because ran out of gas at half full on the fuel gauge.AND I went to fill tank and second tank was full to test theory I ran truck for 100 miles and fill primary tank and the second tank would not take any fuel it was full.
I have tested grounds for sensors and for the pumps all are fine.I ran test leads to the second tank for the fuel pump and it ran . The second tank feeds the primary tank through the over fill hose on primary tank.Both pump leads on primary and second tank are at @5.88 volts when key was on accessory but did not change when I cranked it over.This truck only has one relay for fuel pumps according to parts dept at Chevy dealership so I am assuming the pumps run at same time even flow type system.What would be the correct way to test the sensors on each tank? I have have fluke volt and ohm meter just need to know the correct readings for each sensor?
Old Nov 10, 2009 | 05:18 AM
acnas's Avatar
This should help you out.
http://i187.photobucket.com/albums/x2/acnas/tank.gif
You may have to expand pic. Looks like full is 250 ohms and empty 40 ohms
chevy.man
10
Jul 16, 2010 01:26 PM
waytooevil
Oct 28, 2007 10:48 AM
jackrabbithanna
17
Aug 7, 2007 08:41 AM
chevyrules
8
Aug 1, 2007 06:40 PM
