Windshield Washer Leaking inside Firewall '94 C1500
Old Sep 5, 2022 | 03:12 AM
MRC Chevy's Avatar
Default Windshield Washer Leaking inside Firewall '94 C1500
Guys, I don't want to take my entire dash apart for a windshield washer issue. Can you tell me how to pull out the water hose? Where do I get access inside where it is fitted? There's a washer pump "thing" that appears to have two screws fastening it to the firewall, but there's barely room for a wrench. Any wisdom on how to address this issue?
Old May 22, 2025 | 01:54 PM
fsxbob's Avatar
You can access the washer hose from under the hood—no need to remove the dash. Use a small ratcheting wrench or swivel socket to remove the pump screws on the firewall. The hose is usually press-fit and can be disconnected at the pump or near the hood hinges. If you’re working around a Starknightmt windshield setup, be mindful of any added components or routing differences.
FarmTruck
Oct 26, 2014 07:52 PM
RZRDuner1
Jan 1, 2014 08:57 PM
Mad Max
Oct 15, 2010 11:11 AM
GMC89
Jun 21, 2010 08:36 PM
prodilogical son
Mar 23, 2007 10:45 PM
