worth it?
Old Dec 12, 2007 | 09:21 PM
Derekm162's Avatar
Default worth it?
is getting 1999-2006 Chevy/GMC 1500 Silverado 4x4 - 2" Front Leveling Kit (Torsion Bar Keys) even gona be worth it, how hard is the install and will it really make a that bug of a difference to spend 120 bucks on
http://www.suspensionconnection.com/...con/12903.html
Old Dec 12, 2007 | 09:27 PM
94 dodge ram 2500's Avatar
Default RE: worth it?
I put torsion keys in my 93 chevy and it wasnt the easiest thing in the world because everything was rusted together but on a newer truck like that it might be easier because of not so much rust. you also need a special tool to release the pressure off the key to take it out. when i did mine it took me about 12 hours because of all the rust. it gives the truck a little bit stiffer ride but in my opinon it make the truck look alot better.
Old Dec 12, 2007 | 11:15 PM
kuh99fuss's Avatar
I mentioned this on another message, so if you already read it I apologize......
For just leveling, you don't need to buy any kits. I leveled my 1997 K1500 simply by cranking the torsion bar adjustment bolts. This amounted to in the neighborhood of two to threeinches rise, which easily leveled the truck. I didn't do this blindly. I did quite a bit of research first, as well as analizing the design and mechanics of the suspension system. I am 48 years old, very mechanically inclined, and have spent my life working on and modifying everything with an engine- cars, trucks, airplanes, lawnmowers, and motorcycles. I used a floor jack to raise all weight off the front wheels. I then simply used a combination wrench and made five turns on each bolt. The first thing I did however was to liberally spray good penetrating oil all over the bolts and threads and let it soak for several minutes. All in all it took about fifteen minutes. It rides a bit more stiff, like the 60s/70s era 4x4s. That was a full year and 12,000 miles ago. I have had no problems, no unusual tire wear, etc. If you want to raise it any higher than that, then I do recomend that you look into the various lift kits.
thecure
Jul 16, 2010 09:42 AM
benpfeil
May 2, 2007 01:50 AM
Regal105
18
Apr 10, 2007 12:20 AM
yannawiled
Jan 22, 2007 01:07 AM
beefeater
Dec 25, 2006 12:57 AM
