Changes on Dakota
Changes on Dakota
Is it possible to put 4.7L engine into 4cyl 97 dakota? If so, do I have to change the rear axle? Can I put any transmission on it or is there specific kind only because the truck was originally 5spd.</P>
thanks</P>
Changes on Dakota
they should fit...they frames are the same.</P>
</P>
you may need new mounting brakets...a new wire harness, new PCM</P>
as for the tranny, It doesnt matter between auto or manual...just bolt patterns realy. I wouldnt think the two have the same patterns...but if you find a junked 4.7 just grab the tranny too.</P>
</P>
they axel you have now will be fine</P>
IrishBoar
04-25-2009 10:00 PM
