Where's the heater valve
I have a '93 Dakota (200K). My father-in-law had someone replace the heater core several years ago and he did a REALLY crummy job. It worked for a while and now no heat. We have flushed it several time with a flush kit but still no heat. Someone suggsted the heater valve. I got one from Advance Auto Parts but neither I nor the guy at AAP could find it. Does anyone know where it should be located? Yes, I have looked at the firewall. My father-in-law also has a '91 Dakota. I went out last night to look to see if that truck has one and I couldn't find it ... not under the dash or in the engine compartment. Any help would be appreciated.
The only ones I've seen are inline on a heater hose, and has a vac line on the top..I'll take a look later this morning and post back. If it's where I'm thinking, it's inside somewhat behind the ashtray, against the fire wall.......
Ok, so what I was thinking of was just a vac regulator. I don't know where the damned thing is...LOL!! There's only so many places it can be.......I'll investigate more a bit later. This is a part out truck, so it's all coming out anyways...
In the meantime.. I don't know about AAP...but AutoZone can pull up diagrams on stuff like this, if you have one near you, it's a worthwhile stop. Either that, or head to your local library. They should have a Chilton's in the reference section.
~Rovin
~Rovin
RovinAround,
Thanks for looking and your suggestions. I looked again (flashlight in hand) and I still couldn't find it. I'll definitely call AutoZone and check the local library for a diagram. I really appreciate your time and opinion. If I find out where it is located, I'll reply at a later date. Thanks again.
