'96 1500 vacuum problem
Old Feb 12, 2008 | 04:40 PM
bq93's Avatar
Default '96 1500 vacuum problem
I have a 1996 Ram 1500 and I’m having some sort of a vacuum problem.
There are a couple of issues – first it won’t idle smooth. The idle goes up and down about 500 RPM every few seconds. Also – If you have the A/C on and run the RPM’s up (say leaving a stop light) the air moves from the front A/C vents up to the defroster. When you reach highway speed it will return to the original setting.
I am really a newbie to this truck so I have no idea where to start trying to diagnose this problem. Vacuum lines????
Any advice is appreciated.
Old Feb 13, 2008 | 05:53 AM
Argon's Avatar
Default RE: '96 1500 vacuum problem
THERE SHOULD BE A VACUUM TANK UNDER THE HOOD....MAKE SURE ITS PLUGGED IN..THEN FOLLOW THAT HOSE
Old Feb 13, 2008 | 10:03 PM
Mark 99 Ram's Avatar
I had an 97 Ram with the same problem with the vents when you accelerated from a stop sign. Mine started right after I put spark plugs and wires on it. Found out that I must have accidently pulled a vaccum line apart trying to reach the distrubitor cap. With yours idling weird I would defenitly check a vaccum leak probably a larger one if it is running weird. I would check around the intake or throttle body area first. You should be able to hear a leak if you listen close enough. Just my .02 cents
Old Jun 20, 2011 | 07:33 PM
JLR25's Avatar
Default ac possible solution
there is a one way valve on a vacumn line next to the throttle body on passenger side may be bad. dealer cost around 10.00.
jlr25
90 Dakota S/E Conv.
Mar 9, 2008 05:16 PM
72charger
Sep 19, 2007 07:54 PM
MACHINEGUNNERTODD
Aug 4, 2007 09:13 PM
stopspazinout
8
Jun 17, 2007 04:18 PM
calicowboy
Jun 30, 2006 10:09 PM
