Ball Joint replacement 2004 2500 heavy duty 4x4
Old Jun 30, 2011 | 11:13 AM
skatafrata's Avatar
Default Ball Joint replacement 2004 2500 heavy duty 4x4
After replacing both front sides with new hub bearings I found that I need ball joints at least on the driver side. I will however replace both sides.
Do I have to remove the front hub assembly which I just replaced in order to remove and replace upper and lower ball joints (and would it get damaged coming off if so?) or just the brake parts? Will anything else need to be removed? I will be able to use a lift with all kinds of tools available.
I also bought greasable ball joints since they seem to last longer.
Please respond as soon as possible because I plan to work on this truck on Sunday 7/3 and only have a 5 hour span for use of the lift. Anyone's help will certainly be appreciated. Thank you.
HugeF250Lift
Oct 22, 2009 11:38 PM
S70P
Oct 18, 2008 09:03 PM
uscghalle
May 9, 2008 05:48 PM
majordad
Nov 5, 2007 06:36 AM
majordad
Oct 18, 2007 10:05 AM
