I've tried EVERYTHING!!
Old Feb 15, 2010 | 02:38 PM
shibbyman22's Avatar
Default I've tried EVERYTHING!!
I have a 96 Ram 4x4 with the 5.2 318 that i just bought three days ago and drove it it over 3 hours home with no problems. When i got it home it started to cut out on me and died the very next day. Found out the fuel pump was out so i changed it. Now upon re firing the engine it stalled immediately and has done the same since. I know it's a fuel problem cause if u feed it gas through the TB it will stay running fine. I have replaced the IAC, TPS, and the crank sensor is new cause i have a reciept from the previous owner and i also checked it and not a scuff on it. I have checked and swaped all fuses and relays and checked all connectors, looked for leaks and pinched lines. would a scanner help even though i have no codes showing via check light? anything would help right now don't want to take it to the shop and have it cost me a fortune.
Old Feb 22, 2010 | 01:37 AM
numbvir's Avatar
i ve never been so,hope someone can help u
Old Feb 22, 2010 | 03:34 PM
Hollonator's Avatar
I never seen you mention changing the fuel filter, cleaning out the fuel tank, and blowing out the fuel lines. It sounds like its just a case of bad gas that you might of picked up on your 3 hour trip.
Old May 22, 2010 | 12:25 AM
Nando Vazquez's Avatar
I agree there is nothing else I can think of. You could also try Seafoaming the fuel system, that should help get rid of most of the filth and contaminants that could be damaging the system.
carid
Member Group And Special Buys
Apr 10, 2015 08:07 AM
chrisbmo2000
Jan 31, 2009 05:14 PM
shackled
Jan 15, 2009 03:43 PM
MrLM7
May 4, 2007 04:52 AM
jordansportsfan
Feb 22, 2007 04:54 AM
