Low speed stalling after major tune.
Old Mar 22, 2005 | 05:17 PM
goldauto's Avatar
Default Low speed stalling after major tune.
Recently I tuned up a 1995 Dodge Ram 1500, after plugs, rotor, cap, and wires it has developed a bad habit of stalling at speeds equal to granny gear, a creep speed. The engine will falter and the rpm's will drop to zero, sometimes it will stall out and sometimes it will recover, very annoying in traffic at a light. No starting problems, with normal acceleration and cruising at all other times.
Can anyone shed some light on this? My mechanic says take it to the dealer, he can't figure it out.
Thanks, Gold Auto
Old Mar 22, 2005 | 07:30 PM
Patrick's Avatar
Default RE: Low speed stalling after major tune.
do you have the parts that you took off still?? i would think it may be an issue with the new parts..maybe a bad coil wire or plug wire...or a bad dist cap...
Old Mar 28, 2005 | 10:25 PM
DWhiteDevil's Avatar
I agree I get a bad new part a least once a day at work, it happens.
Old Mar 29, 2005 | 01:09 PM
Patrick's Avatar
when i was a tech..i had someone send me a bad alternator...i dont recall what it was in, but it was something that i had to get insie the LF wheel well...pull the shield out...it was a nightmare...[:@]
Old Apr 2, 2005 | 10:42 AM
goldauto's Avatar
Thanks for the input guys, but that doesn't solve this one. I took it to a mechanic and he thought it might be a restricted vac line someplace, he checked and I checked but found nothing.
I tried surfing and searching and the only thing I came up with was a comment that the plug wires need to be replaced exactly as original. Now there's a fine bit of information, the distributor cap is against the firewall and nearly burried, I can almost see where the lock down bolts are to remove them and when you remove the plug wires from the birds nest, how would you ever get them back exactly where they were? All I need now is a diagram or instruction of what the standards are for this repair. Lucky me I broke the rear wire tree that holds all the wires in place. Life goes on!!
Old Apr 2, 2005 | 03:05 PM
Patrick's Avatar
are you certain that the cap is in the same position as it was before you changed it? if you have the cap turned at all, you throw the timing out of whack....
Old Apr 4, 2005 | 11:33 PM
Oh god, time to find TDC, break out the breaker bar[sm=signs003.gif]
duby55
Feb 20, 2014 10:04 AM
kmg4broncos
Mar 23, 2010 12:23 PM
LyncoSas
Jan 30, 2009 05:24 PM
silverado_ia
Jun 14, 2007 11:02 PM
fixitaz
Apr 28, 2007 09:49 PM
