Dodge/ Ram General Tech Dodge tech talk within.
1993 ram d250 brake problems.
Old Mar 19, 2010 | 08:39 PM
cupofjoe1971's Avatar
Default 1993 ram d250 brake problems.
I have a 93 d250 diesel. had a loud noise in the front end when i hit bumps. my calipers are bending the retainers and hiting the rims and rotor hub. replaced keeprs four or five times already. after driving for a short time it starts again and gets worse. no idea what is wrong or to do to fix the problem.
Old Mar 20, 2010 | 12:13 PM
chrisbmo2000's Avatar
have you replaced the calipers? How about the spindle? these could be worn and not allowing the retainers to stay in.
Old Dec 16, 2010 | 02:45 AM
AbleSmith's Avatar
Banned
Check the housing and the lines that connect the booster with the steering power system for signs of wear and damage. Make sure the connections are tight and dry. Look for signs of leaks at the connections and run your fingers along the lines to find hidden leaks from view.
Old Feb 10, 2011 | 10:44 PM
AbleSmith's Avatar
Banned
There might be dust in the drums, or may be brake shoes has been distorted or broken or sutured lining. The noise your are hearing may be a bad wheel bearing. Kindly check out these things for better result.
Last edited by Worf; Feb 25, 2011 at 07:16 AM. Reason: removed spam link from post
Old Feb 11, 2011 | 05:55 AM
hjfisk's Avatar
Sounds like you are describing bad wheel bearings, I wouldn't drive it anymore till you check it out, hard saying what damage has been done
Old Feb 21, 2011 | 01:49 AM
atul1's Avatar
Kindly check to see your brake fluid, if it is low, then feel it to the mark on the side of reservoir.
Old Feb 25, 2011 | 05:50 AM
atul1's Avatar
Kindly check the caliper, check whether it is frozen or worn, if then needs to be replaced. Kindly check out Shocks and springs which can cause noise when braking if they are broken or loose.
Last edited by Worf; Feb 25, 2011 at 07:17 AM. Reason: removed spam link from post
Old Mar 1, 2011 | 01:05 PM
kingrob84's Avatar
Old Mar 14, 2011 | 02:12 PM
bigghoss28's Avatar
Default Hey Chief
When it comes to problems like that, it is always better to let a TRUSTED professinal to take a look at it. It really could be anything, and remember the only thing linking u to the road r your wheels, don't chance it
jbhofc
Nov 10, 2008 10:20 PM
robigarr
Apr 13, 2008 04:17 PM
sandknob
Aug 23, 2006 01:10 PM
sandknob
Aug 22, 2006 10:33 PM
lappin
Mar 15, 2006 05:41 PM
