Sponsored by:
Sponsored by: Kumho
86 f-150 5.0 EFI won't start without ether
Old Dec 16, 2011 | 08:47 PM
TrueBlue72's Avatar
Default 86 f-150 5.0 EFI won't start without ether
My 86 f-150 5.0 won't start unless I give it a shot of ether, once I do that it fires up and runs great. Two weeks ago I parked it and everything was working fine, when I tried to start it yesterday it wouldn''t start until I sprayed it, I wonder if this could be a bad sensor or perhaps a wire has been damaged by a mouse or something, I see some acorns on the intake.
I'm lost at this point, any advice would be greatly appreciated.
Thanks
Old Feb 15, 2012 | 01:35 PM
Destry Alan Foyte's Avatar
Destry Foyte says he doubts that it is from a mouse or electrical. More then likely some sort of fuel problem, such as a fuel pump or injector problem. let me know what you come up with. hope this helps. From Destry Alan Foyte
Old Feb 15, 2012 | 06:11 PM
Worf's Avatar
First thing i would do is check for fuel pressure with the key on but before you try to start it the first time
Old Feb 16, 2012 | 07:08 AM
TrueBlue72's Avatar
The problem has been taken care of, sorry I forgot to post the result.
It was in fact the TPS ( throttle position sensor ) it completely failed and
that was telling the computer the throttle was wide open and there was
too much fuel, In turn the computer tried to correct the problem and
shut down the fuel on start up. I removed the throttle body, replaced the
TPS and everything is fine.
Thanks everyone!
godrocksus1
Mar 22, 2010 08:50 PM
fordpower01
Jul 12, 2009 09:20 PM
ChurchBuilder
Jun 7, 2009 01:56 AM
91DakotaZurbyk
Sep 19, 2008 01:16 AM
alexhasatruck
Nov 20, 2007 06:35 PM
