Sponsored by:
Sponsored by: Kumho
need advice on programmer 1994 5.0 v8
Old Nov 15, 2011 | 10:27 PM
good?'s Avatar
Default need advice on programmer 1994 5.0 v8
Im looking for a chip/ programmer for my 94 f150 5.0l 302 4x4 automatic.
i want something that i could switch between economy and towing easily. do they make something that stays in the truck permanently?
Old Nov 19, 2011 | 02:41 PM
good?'s Avatar
Default help!
is there no one who can help me?
Old Feb 16, 2012 | 11:35 AM
Destry Alan Foyte's Avatar
Destry Foyte says that unless you do something with the engine ecm (electronic control module) there is not much out there but scams. Most $60.00 power chips they call them don't do much if anything. Most try to trick the ecm into thinking it is getting the best air through a couple of Radio Shack diodes that use voltage to trick the ecm. Which then forces it to inject a different ratio of fuel through the injectors to achieve some sort of noticable fuel economy. This in fact can make the truck run worse depending on certain climate conditions. So unless you go right to the ecm which can be very expensive and voids warranty there is not much help out there. Hope this helps.
Thanks
Destry Foyte
txag10
Silverado/Sierra FAQs
Aug 23, 2009 02:49 PM
chevyman02
Dec 15, 2006 05:13 PM
keisuke takahashi
Jul 28, 2006 10:44 AM
radioflyer
Aug 26, 2005 02:04 AM
Blake N
Jun 25, 2005 04:11 PM
