Sponsored by:
Sponsored by: Kumho
Power/missing issues
Old Aug 5, 2007 | 11:15 PM
OldeWolfe's Avatar
Default Power/missing issues
I have a '95 F150 with a 5.8L, E4OD and dual tanks.
The symtoms I have are:
1. Semi-rough idle
2. Low power.
3. Engine 'misses' or hiccoughs occasionally under load (hills, acellerating) in 3rd and 4th
4. Tach 'bounces' throughout entire curve
5. Cruise no longer works, but does turn on
Tested items:
Fuel:
Pressure reads 35psi key on-engine off. 30psi engine running. 40psi engine running with vaccume disconnected from the regulator.
New fuel filter
Same symptoms/readings with either tank selected
Vaccume is 21 in Hg during idle and drops normally with throttle
Ignition:
New plugs
New T.F.I. module
Cap/Rotor and wires 8 months old. Distributor 4 years old
At idle, timing is 10 BTC with spout removed, ~17 BTC with spout installed
Coil resistance is 0.5 ohms on the primary, 8.6 ohms on the secondary. I verified this with a new coil at Kragen, the new coil read the same.
Computer:
Tests OK
No codes
No 'Check engine' light during operation
I'm at my wits end on this. Any ideas would be appreciated.
Old Aug 6, 2007 | 04:56 AM
Argon's Avatar
Default RE: Power/missing issues
USUALLY,a bouncing tach means a primary ignition fault...like a coil...wett cap,etc
frootfel1
Sep 3, 2008 10:45 PM
Stonehouse
Oct 27, 2007 03:41 PM
donwag
9
Apr 4, 2007 12:04 AM
wylie01
Aug 31, 2006 04:50 AM
Tony
Aug 14, 2006 06:21 PM
