fuel pump
Old Feb 13, 2012 | 04:22 PM
mikeyt5060's Avatar
Default fuel pump
I have 90 f250 replaced engine with block from 95. at first fuel pumps kept running whether the key was on or not just as long as battery was hooked up.
fixed that problem with new relay. now fuel pump shuts off with key. but with key on fuel pump does not shut off. wont start unless i spray starting fluid in intake then it starts and stays running. then it will start on its own . until after it sits for some time.
any ideas would be appreciated
thanks mike
Old Feb 13, 2012 | 05:34 PM
Worf's Avatar
The truck will not start up on its own? Do you have fuel pressure the first time you try to start it?
Old Feb 13, 2012 | 08:41 PM
mikeyt5060's Avatar
thanks for replying. ya when i turn key on fuel pressure goes right to 40 psi
Old Feb 15, 2012 | 08:55 PM
mikeyt5060's Avatar
thanks for your input Worf it ended up being the ecm
In2Trux
Apr 19, 2015 08:50 PM
ecarri100
Jan 9, 2011 09:54 AM
chrisbmo2000
Dec 24, 2010 03:35 PM
needshave
Jan 24, 2010 12:53 PM
jrk99
Dec 7, 2009 11:57 PM
