Help on Headlight upgrade
Old Feb 22, 2009 | 06:35 AM
tino578's Avatar
Default Help on Headlight upgrade
I just purchased a 05 F350 XL superduty and the truck came with the old style conventional "square headlight sealed beam" and I was wondering If I could replace them with the fancy XLT headlights from another 2005. Could some one right off the bat tell me that they can be swapped without modification?
Thank you very much!
Anthony
Old Mar 5, 2009 | 09:52 AM
HeavyAssault's Avatar
I haven't seen this done myself, but the mounting points are the key. If the old housings have two mounting points top and bottom then it should be a straight swap. You would need to check the wiring plugs as well. If you post up some pictures of what you have now of the mount points and plug I could probally tell you.
SpottyJ
Aug 10, 2009 09:05 PM
jadimon
Jan 11, 2007 06:06 AM
Trekerjohn
Oct 29, 2006 02:22 AM
briggs4811
Jul 2, 2006 05:56 AM
ProRider199
May 15, 2006 09:17 PM
