My '95 Ford F-350 d-side rear drum brake worn to the metal, other side fine, any ideas as to cause?
Old Oct 31, 2007 | 09:04 AM
7freedom7's Avatar
Default My '95 Ford F-350 d-side rear drum brake worn to the metal, other side fine, any ideas as to cause?
No springs broke.
Wheel cylinder not leaking.
Got a replacement drum from Pick and Pull off a '90 F-350 but is at the max diameter, is it safe to use?
Also got the brake shoes from same truck.
Pick and Pull said only '94 to '97 would fit, however couldn't find any of those, but this one appaers to be very similar and measures the same. Could their computer be wrong should I use this drum?
I also took the wheel cycliders from the '90 but both started leaking when I took the brake shoes off, does that mean they're bad?
Thank you very much in advance.
Old Oct 31, 2007 | 10:41 AM
Argon's Avatar
Default RE: My '95 Ford F-350 d-side rear drum brake worn to the metal, other side fine, any ideas as to cause?
Yes,they are bad..
make sure the shoesare adjusted evenly when your done....
jte52003
Feb 6, 2012 06:42 PM
paparoach
Jun 25, 2009 08:21 PM
06Z71
Sep 14, 2007 05:07 AM
Sinjin1952
Nov 5, 2006 03:51 PM
zdb350ci
Aug 9, 2006 09:11 AM
