'77 Chev C10 Possible carb problem?
Old May 22, 2009 | 05:14 PM
tylerjca's Avatar
Default '77 Chev C10 Possible carb problem?
Hi all
I'm new here and by no means am I a mechanic or mechanically inclined, but I am slowly trying to restore, or at least make my truck road worthy.
It is a 1977 Chevrolet C10 and has a problem with starting. It seems to only run well in the heat, or after the engine has warmed up to around 150 Degrees (water temp). If the engine is cold, I have to do the following:
-pump the gas a few times while key is turned
-turn key (attempt to start) 2 or more times
-keep my foot lightly on the gas once started to keep it running until engine reaches running temperature
Would this a carburator problem?
Thanks
Old May 22, 2009 | 08:29 PM
Sounds like your choke is not working properly or at all on the carb. What kind of carb is it and do you know if the choke is connected?
Old May 26, 2009 | 06:30 PM
tylerjca's Avatar
I'm not sure what kind of carb it is, but before I posted here I didn't know what a choke looked like (yes, like i said I'm not very mechanically inclined when it comes to cars), so I looked it up on Google Images, and watched a couple vids on how to adjust it.
You were correct, after making a small adjustment to the choke it started up and remained running nice and smoothly on the first try.
Thanks very much
Old May 26, 2009 | 08:58 PM
RUFFNECK4LYFE's Avatar
Sweet call shamrock!!
Old May 26, 2009 | 09:16 PM
Thanks Ruffneck...glad we could help!
GarryB
Aug 28, 2010 05:14 PM
kippton
Jul 7, 2010 05:11 PM
archerobx
Mar 30, 2010 09:31 PM
problemchild98
Nov 15, 2009 06:33 PM
Eastfrisian
Nov 5, 2008 04:30 AM
