96 Vortec engine problem, experts needed.
Old Dec 2, 2006 | 11:20 PM
Fryguy302's Avatar
Default 96 Vortec engine problem, experts needed.
Summary of my questions:
1. What can cause HC to show up in the coolant other than a head gasket?
2. Can a head gasket be blown or a head cracked even when the truck runs great, has great power, doesn't use coolant, and passes cylinder pressure and coolant pressure tests?
I'd much appreciate it if any experts can answer the above two questions for me. If you want to read the long version, here it is:
Trying to figure out my newly purchased 96 Yukon. I know the previous owners of this truck and know the history on it. For the past year, it's been having a problem starting when cold. It is NOT the typical fuel pump or regulator or ACT sensor issue, because the problem is the way in which the truck CRANKS when cold. When it's cold, it cranks fast for maybe one revolution, then cranks really slow (too slow to start sometimes), almost like something is binding up or the starter is failing. The starter has been changed twice since this problem presented itself about one year ago. The battery has also been changed. The previous owners continued to drive the truck every day like this.
When I bought the truck, I dropped it off at a local shop for diagnosis, expecting them to find a bad ground or a bad positive cable, or maybe a bad starter.
They shocked me by telling me that the head gaskets were probably blown or a head was cracked. They told me they put a wand to the coolant and there were hydrocarbons in it. They also told me they did a propane test and there was an intake leak. When I asked how that affected the starting, the tech told me that he thought maybe it was actually hydrolocking because of coolant in a cylinder. He told me I should probably just put a new motor in the truck, since it has 100k on it anyhow.
At this point, let me tell you how great this thing runs. The oil has been changed every 3k miles for the last 65k (that's how long the previous owners had it). It idles quietly, runs and drives great and is very strong. When I picked it up from the shop, I had my buddy drive it home, and I followed him, so that I could look for smoke. He stood on it one time, and not only was there no smoke, but my brand new 5.4L F150 could not even keep up with the old Yukon, he just walked away from me, even though I had my new truck floored.
We got it home and did the following:
1. Pulled a valve cover just to look. No milkshake and not even any sludge. Looked like new. Oil on stick looked great also.
2. Pulled plugs. No sign of any cyl. burning coolant.
3. Did a cylinder pressure test. Lowest hole = 190, highest hole = 195. I've put seen brand new motors which were less consistent than this.
4. Did a cooling system pressure test. Dropped 2psi in 9 minutes.
The previous owners were shocked, and swear that this truck has never overheated or used coolant. I drag race as a hobby, and run a Mustang that's had many different superchargers on it and is now turbo charged. I've blown a LOT of head gaskets in my day, and I've never seen one like this with no symptoms.
Please let me know what you guys think. Any help would be greatly appreciated
Old Dec 26, 2006 | 01:07 AM
99z71325ci's Avatar
Default RE: 96 Vortec engine problem, experts needed.
sounds like that shop you took it to is in need of some money. i say get a multi meter and do some voltage drop testing in your ignition system.
Old Dec 29, 2006 | 08:42 PM
sc64chevy's Avatar
They were probably right as far as the intake gaskets, these trucks are notorious for those going bad. This was the first year they had the vortec v8 and they have those plastic gaskets with the rubber seals in them. They were normally leaking by 100k. As far as replacing the motor just because of the miles is really poor advice. And id have to agree with 99z71 above about the voltage drop test.
dirtybiker414
Jan 16, 2012 01:52 PM
jaxontipedeau
GM How-To's and Tutorials
Jan 31, 2011 04:17 PM
joker113
Jan 30, 2011 04:23 PM
Mr_Shamrock
Dec 22, 2010 09:35 PM
Cedonulli
Sep 20, 2010 12:29 PM
