98 fan blower switch problem
Old Jul 4, 2008 | 09:11 AM
Larry G.'s Avatar
Default 98 fan blower switch problem
I have a 98 chevy truck. The fan blower switch only works on high. Any ideas on what may be malfunctioning or what needs to be replaced? A couple of years ago I put a different radio in the dash and am wondering if I may have damaged the blower switch or wire assembly leading to it. The blower switch continued to work after I put the new radio in for at least a year.
Old Jul 10, 2009 | 10:22 PM
angrydook's Avatar
it could very well be the resistor, but that wasn't so in my case. i have a 97 sierra and the problem was a melted wire harness behind the blower control dial. the clip that goes to the wiring harness and the clip that plugs into the back of the blower control dial were both melted. this is a common problem from what i've heard. I went to a wrecker and got both pieces from a write off that weren't melted and installed them today, blower works on all speeds ... for now.
Old Oct 18, 2009 | 10:04 PM
duckhunt's Avatar
Member
Probably is the blower motor, you can get a new one fairly cheap from http://www.gmpartsclub.com/chevy-silverado-parts.html Its a pretty simple fix to do yourself.
4chevytrucks
Dec 27, 2016 07:26 AM
Whitaker24
8
May 9, 2010 03:11 AM
wolfeman5
Mar 26, 2010 07:05 AM
gtsfirefighter
May 8, 2008 02:28 PM
dickperry
Aug 16, 2007 02:38 PM
