argon do you know?
Old Aug 25, 2007 | 12:43 AM
stopspazinout's Avatar
Default argon do you know?
do you know if the throttle bodies between a 305 and a 350 are different?
Old Aug 25, 2007 | 05:21 AM
Argon's Avatar
Default RE: argon do you know?
no..but the injectors in em may well be...I know a 454 has a different injector....easy enough to swap though
Old Aug 25, 2007 | 10:41 PM
minus the price of course
Old Aug 26, 2007 | 06:18 AM
Argon's Avatar
If ya take it apart,replace the fuel reg./...just about all of em on tbi's drip
Old Aug 27, 2007 | 03:00 PM
well what it is, the injectors seem to have a more delayed injector pulse especially at idle than they used to. also hearing some kid of vacuum leak coming from around the tbi, i knoticed the throttle bore has gotten really dirty. everything else in the fuel system is new. so im thinkin a new throttle body with 350 injectors in it.
Old Aug 27, 2007 | 05:57 PM
Argon's Avatar
may be...
but I think the hiss is the base gasket...common on those...and 2 injectors and a fuel reg....and thats all the "wear" parts on it
Old Aug 27, 2007 | 09:55 PM
i dont think its the base gasket, ive replaced the base gasket 2 or 3 times now and its still there.
Old Aug 28, 2007 | 05:12 AM
Argon's Avatar
ok..do you hear the hiss with the breather off?...they will suck prett loud.
could be the throttle shaft,I guess
Old Aug 29, 2007 | 08:05 PM
yes its worse with the breather off, i didnt notice this hiss until the time i started having a cold idle problem
stopspazinout
12
Oct 24, 2007 09:30 PM
stopspazinout
Aug 25, 2007 10:40 PM
chevyrules
Jul 14, 2007 04:59 PM
MrLM7
Jul 12, 2007 09:50 AM
