electrical problem
Old Feb 8, 2007 | 02:10 PM
chevyguy#1's Avatar
Default electrical problem
listin every one i have a k5 blazer 1987 and when i went around a corner my truck shut down now i have no power to anything i tried to locate the slelinode i cant find that. my battery isfine and charedi am stuck can any one help me out and put me in the right place
thank you
corey
Old Feb 23, 2007 | 08:22 AM
Starbud's Avatar
Default RE: electrical problem
it can also be some relay or some connector that has some oxide and broke the connection just when you turned.
Maybe you can handle them to make contact and thereby find one or more of the faults that way.
Old Feb 25, 2007 | 02:04 PM
00ShortBoxChevy's Avatar
That happened to me with my old bush truck, it's an 88 4x4 Silverado. I was on the highway, punched it to pass someone and everything powered down. The speedometer stayed exactly where it was, fuel gage went to full, turned out to be the ECM ground on the thermostat housing that broke. I guess it was just holding with a few strands of wire and the sudden torque of the engine caused it to breakoff when it rocked.
Old Feb 25, 2007 | 04:45 PM
Argon's Avatar
An 87 still had fusible links at the starter..I'd look there
sickshoesbrah
Mar 9, 2007 06:26 PM
PJBZ71
12
Feb 28, 2007 09:32 PM
Mcfish
Nov 30, 2006 12:46 AM
quadracer
Feb 16, 2006 08:41 PM
chrisselfz71
Nov 15, 2005 09:36 PM
