A few Questions about my Silverado
Ok..I just bought a 1999 Silverado Z-71. It has 131k on it and I have a few questions:
1. Why does my gas gauge just decide to stop working at random, usually at idle? It will either register Empty or bounce back and forth from Empty to Full. Is this something easily remedied?
2. I hear a vibration when I enagage my Auto 4x4. I also notice a diminshed turning radius or I hear the grinding/rubbing noise. Is this expected? This is my first 4x4 so I am not 100% certain what I should/shouldn't hear.
3. Where can I get the fog lights that go in the air dam on this truck? Mine are both broken.
I think that's it for now. Any help would be greatly appreciated.
thanks
Dougo
thanks
Dougo
Wow, old thread, sorry it slid by.
1. Common issue with these years Silverado's. The sender is in the tank and is part of the pump and the only way to fix it is to replace the assembly.
2. That is not normal for Auto 4X4 it sounds like it is engaging when it is not needed. There are a few things that can contribute to this issue, but not being a big 4X4 guy myself hopefully someone with more knowledge of what causes the Auto 4X4 to engage will chime in. I would imagine there is a sensor that can tell when the additional traction is needed.
3. I would try eBay or you might try the dealer. Some things are a cheaper than you might think from the dealer (not usually, but I have been surprised). I have a connection with Keystone Automotive here locally that would probably have the lights aftermarket if you can't locate them.
When you hear the rubbing noise are you turning as hard as you can? And do you have oversized tires on it? The rubbing noise could be you tires rubbing on your truck. I also had this problem with my old truck and it was a front U-Joint when it was in auto 4X4 and it vibrated really bad.
Is this indicative of a problem with the pump or just an irritation?
thanks
Dougo
thanks
Dougo
Carmelsteve
Feb 23, 2011 07:32 AM
JumboShrimp
10
Mar 29, 2007 12:26 AM
