rear end question
Old Jul 30, 2007 | 11:16 AM
Indycar68's Avatar
Default rear end question
I have a 77 3/4 ton with a 10.5" full floater rear end. What would make the right brake area get soaked with differential fluid, when it is designed not to, with no axle seals?
Old Jul 30, 2007 | 12:53 PM
Argon's Avatar
Default RE: rear end question
what do you mean "no axle seals???"..there must be something there
Old Jul 30, 2007 | 01:02 PM
Indycar68's Avatar
No, the axles bolt to the drums, and you use gasket sealer to seal it there, but that doesn't seperate the fluid from getting to the taper bearings in the drum. It seems as though it was designed so that the fluid isn't supposed to go there in the first place???
Old Jul 30, 2007 | 01:13 PM
Indycar68's Avatar
Or, is the diff fluid supposed to get to the taper bearings? It looked as though they were lubed with wheel bearing grease. If it is supposed to, then obviously I just have a bad seal in the back of the drum. But I don't know if those bearings are lubed by the diff fluid, or wheel bearing grease.
Old Jul 30, 2007 | 01:32 PM
Argon's Avatar
The 90w lubes the bearings...the axle seal is inside the drum...fluid cis getting past that if the shoes are oily
bam2880
Jul 4, 2011 04:25 PM
93Z71
Mar 13, 2011 10:58 PM
72oreo
8
Feb 16, 2010 08:42 PM
ABSPUD
Jul 18, 2009 03:59 AM
Drifter59
May 15, 2009 01:11 AM
