Set Timing 1989 K2500 350 CID
Old Sep 7, 2007 | 07:08 PM
Daddy Wags's Avatar
Default Set Timing 1989 K2500 350 CID
I need to set the timing on the above vehicle. I need to disconnect the single wire (Tan w/black stripe) behind the plastic cover on the pass firewall. Where is that wire? Which plug is it? Is it in the middle, left, right?
Old Sep 7, 2007 | 08:00 PM
Argon's Avatar
Default RE: Set Timing 1989 K2500 350 CID
its on your right as you look at the firewall with the cover off...it may have a bit of tape around it...a 1-wire black connector
Old Sep 9, 2007 | 10:15 AM
Daddy Wags's Avatar
Found it. Thanks.
Justin Schneider
Aug 26, 2013 08:57 PM
CMontgomeryCO
Mar 5, 2012 10:47 PM
broozersnooze
Apr 27, 2010 10:28 PM
Thraxxx
Oct 22, 2007 04:31 PM
el camino
Sep 12, 2007 12:37 AM
