water temp
Old Sep 30, 2007 | 09:06 PM
bigdirtychevy's Avatar
Default water temp
hey guys im bryant. new to this site and im hoping yall can help me out. i have a 96 tahoe with a 5.7 v8. recently my truck has been acting weird when driving. my water temp will jump up to warning level, and then immediately drop back down to normal..then periodically it will do it again, then drop back down. i have no idea what i can do to fix this problem. a couple months ago i flushed my radiator, it has a new water pump, alternator and AC. i was told to replace the sensor thats right under the thermostat neck, so i did but didn't fix it..was also told it woudl do this if there was air in the system, so i ran it, then loosened the new temp sensor so that some fluid could come out and then ran it again and it still didn't fix it..any help would be much appreicated! thanks sooo much!!!!
Old Oct 1, 2007 | 03:49 AM
Argon's Avatar
Default RE: water temp
It certainly sounds like its low on coolant...If not,could be the gauge or sender...
I THINK..on that 96...you rep[laced the wrong sender...the one by the thermostat tells the ECM the temp...the gauge sender is at the LF head
In2Trux
Apr 19, 2015 08:50 PM
Ballzac
25
Apr 5, 2007 02:49 AM
tjlmbklr
Mar 13, 2007 10:04 PM
d1986
Sep 13, 2006 01:18 AM
tripuhlet
Oct 3, 2005 09:13 PM
