Help with buying a clutch
Hello everybody .
I have a 2004 GMC 1500 Sierra. 4.3 , 4 x 4 , 5-speed manual
After 249,000 miles of overwork , the shaft coming out of transmission went smooth . I got a remanufactured trans on order , but my mechanic told my to get my own clutch kit . I don't know anything about them and was hoping some folks here do . What do people recommend buying , and recommend avoiding ? Any input would be appreciated , thanks .
You will need a clutch kit that fits your 2004 GMC 1500 with the 4.3L engine and 5-speed manual transmission. A full kit should include the clutch disc, pressure plate, release bearing, and pilot bearing.
Many people go with brands like Luk, Sachs, or Valeo for a stock replacement. Luk is a common choice because it is affordable and works well for daily driving. If you tow or haul heavy loads, you might want a heavy-duty clutch, but for normal use, a standard kit should work fine.
Try to avoid cheap no-name brands because they might not last long. Also, make sure the kit you buy matches your truck’s specs.
Hope this helps.
Hope this helps.
