GM How-To's and Tutorials Have a project you're working on? Take pictures and write up a procedure...We'll post it here!
Is it possible to bypass ABS unit.
Old Jan 18, 2011 | 05:20 PM
Campbells's Avatar
Default Is it possible to bypass ABS unit.
Hello
I own a 98 GMC Sierra Z71.
I have recently been having problems with my brake system. I have had everything looked over and or changed. My break pedal is spongy and I am able to push it all the way to the floor. My breaks do work, when the pedal is compressed all 4 tires will stop, but there is not much to the pedal. I have myself bled the line a number of times and have also had a professional bleed them and look over the system.
I have been told that possibly the Dump Valve in the ABS unit is stuck or not working. I do not want to buy a new ABS unit and I am wondering if anyone knows if the ABS unit can be bypassed entirely and how?
Thanks.
Old Feb 21, 2011 | 09:14 PM
Matt D Cat's Avatar
I've got a '97 Silverado and the ABS light has been on since I bought it about a year ago. I looked into it and a lot of what I read indicated there were problems with the ABS sensors (located in the wheels) on these years getting dirty, especially in areas where they use salt on the roads in the winter. The dirt, or salt messed up the sensor somehow and made the ABS engage anytime you depressed the brakes, and made them feel spongy and also took forever to stop.
It turns out on my truck, that the previous owner had pulled the ABS relay from under the hood. Doing this does not affect your regular braking in any way, just disables the ABS system.
I just put new pads, shoes, rotors and drums on mine b/c the brakes were getting super spongy and it made a world of difference.
Hope this helps.
Matt
Old May 14, 2011 | 02:24 AM
waltv's Avatar
Pulling the fuse(s) will disable the EBCM and motor killing ABS, but this sounds more like an actual hydraulic issue. It could be an internal issue in the BPMV. I wouldn't be surprised if it were just the master cylinder though. Are you continuously able to bleed air out of the system? If so, I wouldn't think BPMV is at fault.
tcecchi
Silverado/Sierra FAQs
Jul 11, 2011 07:04 AM
GMCSierraFan
Apr 25, 2011 04:38 PM
archerobx
Mar 30, 2010 09:31 PM
SouthBayZ71
Aug 15, 2007 06:51 PM
smoke20
10
Apr 27, 2007 02:23 AM
