Toyota Tacoma Discuss the Toyota Tacoma here
Truck overheating!
Old Feb 4, 2008 | 05:48 PM
drzoid's Avatar
Default Truck overheating!
It's a 99 Tacoma. Coolant level is fine, overflow bottle fluid is where it needs to be.
Replaced thermostat with OEM Toyota one and gasket, OEM radiator cap and flushed coolant and bled air.
It seems to start to do it going over 50-60mph all the time, but, every once in awhile it will do it on the street, 30-40mph. If I don't turn on the heater it seems it will just sky rocket
What is left that it could be? Water pump? Head gasket? How do I check those? What else can I do?
Old Feb 4, 2008 | 07:35 PM
rxsteven's Avatar
Default RE: Truck overheating!
Water pump maybe you might be able to check by opening youre radiator cap to see if its flowing do it wile its cold and you might have to watch until it gets warm and the thermostat opens.
Old Feb 5, 2008 | 04:40 AM
Argon's Avatar
a clogged radiator will get hotter the faster you drive.
as stated,try idling with the cap off...if the water gets puked out ,may be head gaskets
Old Feb 5, 2008 | 08:58 PM
drzoid's Avatar
ORIGINAL: rxsteven
What do you mean by flowing, what should be looking for?
ORIGINAL: Argon
If it were the head gasket, wouldn't I be loosing coolant or be mixture of coolant in the oil?
sal9898
Dec 4, 2008 08:32 PM
rpmc
Feb 22, 2008 08:53 AM
Mazrolet
May 14, 2007 08:14 PM
plow guy
Feb 20, 2007 11:07 AM
mower
Aug 12, 2006 02:39 AM
