180 degree stat
Old Aug 16, 2008 | 10:39 PM
jcormier89's Avatar
Default 180 degree stat
im going to order a stat for my truck here pretty soon, anyboy know how simple/complicated it is to install it in my truck. can i put it in myself (i have some very basic mechanical knowledge)?
Old Aug 17, 2008 | 07:35 AM
wellmax's Avatar
Member
Default RE: 180 degree stat
Question:
why do you want a 180 degree thermostat?
I thought GM engine was to use a 195 degree thermostat as the engine run more efficient at the higher temp range.
Also senors are set for that temp range and will continue to dump fuel in trying to get engine to that temp.
Old Aug 17, 2008 | 12:53 PM
rxsteven's Avatar
You have to change the housing in the 2000s and I think you have to tune it to get the full potential.
Old Aug 18, 2008 | 08:39 AM
jcbst12's Avatar
I can tell you from experience that A. They aren't cheap because the entire housing needs replaced. B. There is no real noticable difference without a tune. (I did notice on a 90 degree day with the A/C on full blast that is was a little spunkier than before the stat). But it wasn't til I tuned it that I noticed a real difference. Having the colder stat will give you a little more lee-way on playing with the timing and fuel trims. Going 160 does nothing more than kill you MPG.
josh29j
Apr 22, 2010 03:40 PM
Cvtsax
Feb 15, 2008 01:48 PM
bradthurman
Jan 14, 2008 11:36 PM
street silver 1
10
Sep 19, 2007 09:57 AM
hunt4game29
Jul 28, 2007 01:21 AM
