1996 Chevy Silverado with a "skip"
Old Sep 7, 2013 | 09:03 PM
chevyman2's Avatar
Default 1996 Chevy Silverado with a "skip"
I've got a 96 chevy Silverado that idles good but "skips" when you shift it in gear. Has new plugs and wires and distributer cap, but it did not help this skipping. The truck also has a new fuel pump so I have no idea what the problem is. It seems to skip worse in forward than it does in reverse or in neutral. If this problem sounds familiar to anyone let me know. It would really help!
Old Sep 9, 2013 | 02:21 PM
TMW's Avatar
TMW
Try injector cleaner in the gas when you fill up.
Old Feb 20, 2017 | 09:10 PM
Tj Castle's Avatar
pull off your air filter and look at your injectors... So long as it is tbi and not the vortec motor... Make sure that both injectors are spraying the same... I had one where one injector was stuck open and the truck would idle pretty good but would pop and skip when driving unless I was flooring it... If all that is good you could have a worn distributor gear
Old Feb 24, 2017 | 10:17 AM
96 will have a vortec motor
k1500j1
Mar 9, 2012 11:39 PM
Silverick
Apr 5, 2011 09:31 AM
DivotMaker
Mar 31, 2011 01:32 PM
MilleArp
Vehicles for Sale
Dec 2, 2008 11:36 AM
abrichford
Mar 2, 2008 09:41 AM
