1999 Chevy Silverado Idles fine but when you give gas the motor shakes and bucks.
Old Jul 19, 2010 | 11:50 AM
  #21
robertbassin5's Avatar
But wouldn't it still stumble with the tps unplugged if I had a bad O2 sensor?
Old Jul 19, 2010 | 11:58 AM
  #22
RUFFNECK4LYFE's Avatar
Im not sure. The TPS, MAF, O2 Sensors, MAP Sensor work together. One goes out and will cause it to run crappy. O2 sensors over time will get lazy. New ones will help alot in idle, smoother acceleration, and MPG.
Old Jul 19, 2010 | 03:18 PM
  #23
I wonder if I a fuel pump going out?
Old Jul 20, 2010 | 12:18 AM
  #24
Would need a fuel pressure gauge to check at idle, start up, and some revs, and shut off.
Old Jul 23, 2010 | 02:19 PM
  #25
Ok guys I have something new going on with this truck. It's already happened twice now Monday I had a little trouble getting it started after sitting for a couple of days, an today the same thing happened. Im beginning to believe it could be my fuel pump. What do you guys think?
Old Dec 1, 2010 | 07:49 PM
  #26
stev02silverado's Avatar
I am curious to know, did you ever figure out a solution to the problem with your truck? I am having the same issues with my 02 silverado. Every time it rains it runs very rough. I have replaced plugs, wires, fuel filter, cleaned distributor, but still the same problem.
Any advice would be greatly appreciated!
Old Dec 2, 2010 | 03:10 AM
  #27
Have you cleaned your MAF sensor lately?
Old Dec 2, 2010 | 01:10 PM
  #28
chevychase's Avatar
I know this is a old thread. But theses trucks the dist. gear would get wore on one side .
Almost knife like. Plus the dist. had too be sealed real good moisture problems. One more thing could be fuel distribution spider getting clogged .
Old Dec 2, 2010 | 08:05 PM
  #29
No I have not cleaned my MAF... I can give that a try. with electronic cleaner?
chevychase- I have read some things about moisture infiltrating the dist. in these trucks... spent too much money at a mechanic [ ] to get it "cleaned" but couldnt bring myself to spend the $400 and might not even be the problem.
Old Dec 3, 2010 | 11:39 AM
  #30
Any parts store has them listed as Mass Air cleaner in a red and white can.
nublood
Apr 3, 2011 10:31 PM
nublood
Mar 23, 2011 12:18 PM
nublood
Mar 23, 2011 11:22 AM
michaelringo
Dec 17, 2010 03:04 PM
Grey Ghost
12
Sep 26, 2007 10:02 PM
