2002 Silverado 1500 won't start
Old Mar 12, 2011 | 08:35 PM
mrk1957's Avatar
Default 2002 Silverado 1500 won't start
This morning I went to start my truck and it just cranks, but no start. I hadn't driven it for a couple days and has been running fine for the four years I've owned it. Fuel pressure is 50-60. I changed fuel filter anyways. Engine[v6] will start only by squirting fuel into throttle body and will continue to run as long I as I keep feeding fuel. I connected a scanner to retrieve codes and scanner does not boot up. I tried the scanner in another vehicle and the scanner works fine. Any help or ideas will be greatly appreciated.
Old Mar 12, 2011 | 09:15 PM
Check fuses when the scanner won't connect. Are you getting the "Service Engine" light coming on for a few seconds when you turn the key on?
Old Mar 14, 2011 | 07:01 AM
mrk1957's Avatar
The blown cigar lighter fuse was the problem, thanks!
Roadcow
Apr 25, 2012 12:54 PM
RandS
Sep 4, 2011 12:10 PM
wolffman
Oct 27, 2006 07:57 AM
newfizzy91
Aug 24, 2006 12:25 AM
