91 Silverado 1500 problem
Old 09-20-2018, 06:06 PM
Chevy91's Avatar
Default 91 Silverado 1500 problem
hello this is my first post. I have a 1991 Chevy Silverado. I recently changed the bulbs on the cluster and now it lights up no issue. But the new problem I have is that the gas gauge does read how much gas it has. I know this because I pumped $70 dollars and it reads less than a quarter. Any ideas how to help?? Thank you.
Old 09-22-2018, 07:44 AM
SlimJim's Avatar
If this problem showed up after you pulled the cluster to change the bulbs, you probably pulled a wire off your fuel gauge. It's easy to break or short a wire when you are doing something like that. I would pull the cluster again and carefully visually check the wiring and you will probably see the problem. Let us know what you find. Good luck.
Chevy91
05-07-2020 04:10 PM
altyson60
08-22-2012 01:08 PM
CMG1002
03-12-2010 12:41 PM
Miazda
09-30-2009 10:33 PM
bigbadwhopper
02-26-2007 01:53 AM
Quick Reply: 91 Silverado 1500 problem
