98 C1500 clunking sound from rear ?
Old Mar 31, 2010 | 08:06 PM
larry posh's Avatar
Default 98 C1500 clunking sound from rear ?
new to the group ..hello guys
my 98 C1500 4.3 auto trans truck makes an intermittent clunking sound when I start off slowly from a stop , ... and occasionally when I slow just at the last minute before a complete stop.
It sounds to me like it is coming from the rear of the truck but I guess anything in the drivetrain could telegraph to the rear end ..
the truck seems to drive well and I don't notice much at regular speeds ..?
anyone have any experiences similar or with ideas ?
thanks again
Larry
Old Mar 31, 2010 | 08:33 PM
It sounds weird but make sure that your spare is tight...been there done that! If it is check to make sure your shocks are tight and that the rubber grommets are still OK.
If that checks, you may need to slide the drive shaft out of the trans and grease the front splines. If they get sticky you will hear it sliding in and out.
Old Mar 31, 2010 | 08:53 PM
RUFFNECK4LYFE's Avatar
I had this done to me one time. Come to find out it was the nuts to the u clamps that hold the leaf springs down to the top of the axle. Somehow they came loose. Just a thought for u to check for. It could be alot of other things too like slip yoke, u-joints, bad rear end, etc.
Old Apr 1, 2010 | 10:07 AM
larry posh's Avatar
thanks guys for the ideas I will get on it today and report back
Old Apr 2, 2010 | 01:24 AM
larry posh's Avatar
had it checked today and nothing obviously wrong found , but the ATF was not red but a kind of pink/ brown so I will do a flush next week ....the mechanic says its a good idea on an older vehicle ...what do you guys think ?
Warlord43B
Aug 10, 2011 04:33 PM
dakota01
Aug 1, 2008 01:03 AM
theduck007
Mar 25, 2008 11:42 AM
wernettejr
Feb 14, 2008 08:00 PM
wareagle
Aug 30, 2007 11:49 AM
