99 sierra no start
Old Jan 19, 2009 | 05:51 PM
gotboost's Avatar
Default 99 sierra no start
i have a 99 my truck was running fine one day then at idel it just stalled replaced fuel pump and come to find outthere is no power going tothe pmpi checked all fuses and there good anyone with ideas
Old Jan 22, 2009 | 04:05 PM
Newfiedan's Avatar
Default RE: 99 sierra no start
If the fuse is good and there is no power to the pump I would start by checking the fuel pump relay see if it is working, if it is then I would start tracing the wiring forthe fuel pumplooking for any areas in the loom that are damaged. There has to be an open somewhere along the power wire to the pump. Option 2 is to run a fused (same as the fuel pump fuse) 12volt wire to the pump to test it, making sure that its functional, note that this for testing purposes only not a fix for your issue.
Old Jan 22, 2009 | 08:41 PM
gotboost's Avatar
checked the relay relay is not clicking does have one power to it does have two grounds tried to jump it and nothing put new relay in it and nothing
Old Jan 23, 2009 | 05:58 AM
Argon's Avatar
make sure the fuse is hot on both sides with a test lite...just because its not blown does not mean its powered up.
if possible,check the gray wire again at the pump with the test lite....not running,you'll only have power on the gray for 2 seconds,so you'll need a helper to s[pin it over while you check it.
rowekmr
Jan 4, 2011 08:25 AM
izod
Feb 6, 2009 01:38 PM
maincity
Nov 25, 2007 05:16 AM
fixitaz
Apr 28, 2007 09:49 PM
odqlesz
Sep 15, 2006 12:31 PM
