ABS LIGHT
Old May 7, 2006 | 01:58 AM
lifted98silverado's Avatar
Default ABS LIGHT
JUST WOUNDERING WHY MY ABS LIGHT IS ON, IN THE MORNINGS WHEN THE LIGHT ISNT ON THE TRUCK DOESNT WANT TO STOP REALL GOOD SEEMS LIKE IT GRABS AND LETS GO REALLY FAST NEED HEKP DONT FEEL LIKE PAY $1600 AT THE SHOP FOR SOMETHING I CAN DO
Old May 16, 2006 | 12:08 AM
EdCrabb's Avatar
Default RE: ABS LIGHT
One of two things causes this. Ether a blow ABS pump fuse, or a blown ABS pump. The pumps on the early trucks used an inferior transistor that burns out long before it should. The action you are seeing is classic. I had a brake shop replace mine with a tested used unit; cost me $155.00 parts and labor. You can pull the fuse and see if it responds the same way only the light stays out. If it does, you got a bad ABS pump.
If you don’t mind bleeding all those lines, it simple to change out. Located right under the drivers seat, inside the frame rail.
But if a shop puts one in and it fails you can always go back and get them to replace it, or if it completely fails, and you loose all braking, then you may be able to hold them responsible.
Check the ABS fuse, if its good pull it and start the truck, see if the light goes out and stays out. Then very carefully take it out and test the brakes. They are supposed to revert back to standard 70/30 brakes.
mic_in_chevy
13
Aug 14, 2014 06:45 PM
05chevytruckguy
Feb 15, 2012 09:58 PM
GMCSierraFan
Apr 25, 2011 04:38 PM
08limited2148
Apr 13, 2010 04:07 AM
dharsen
Jan 25, 2008 12:54 PM
