AC compressor, cycles too often
Old Jul 4, 2020 | 07:06 PM
imariver's Avatar
Default AC compressor, cycles too often
Ok, I have a 91 silverado 2500 ex cab, 5.7 L automatic. Several years back, I had a local AC shop convert my system over to 134A, new accumulater, Compressor, etc. Today, I tried to recharge the AC unit with a DIY "AC PRO" from the local autoparts store. I'm pretty sure that I followed all the instructions, including watching a couple of you tube videos. I filled the system to the high side of the "Green" area, but no cold air. The compressor clutch keeps kicking in and out about every two seconds and while this is going on, the pressure reading jumps (with every cycle) from a little below the green zone, all the way to the high side of the green zone.
Anyone have and advice?
Old Jul 11, 2020 | 01:57 PM
chem_man's Avatar
You really need to get a real set of AC gauges so you can read both the high and low side pressures at the same time. It sounds like your system is low on R134a, but without knowing what the pressures are, it's tough to diagnose. FYI, O'Reilly Auto Parts has loaner AC gauges in their loaner tool program, and I think AutoZone does too.
Patrick Donovan
Jul 1, 2017 04:43 PM
dynedog
Jun 28, 2011 05:23 PM
dodgeman568
Apr 26, 2011 08:27 AM
AZ03silverado
Jul 7, 2008 01:11 PM
Yacovone
May 24, 2006 12:37 AM
