AC compressor cycles when the AC isnt turned on
Old Apr 25, 2011 | 07:05 PM
dodgeman568's Avatar
Question AC compressor cycles when the AC isnt turned on
Hello, I have a 95 GMC pickup with a 350 V8. The AC compressor clutch keeps cycling even though the AC isn't turned on (it does it even when the temp control is turned to heat) Might i add that the heat and air controls seam to be working fine. Would the AC pressure switch cause it to do this if the AC isn't turned on?
Old Apr 25, 2011 | 08:27 PM
Default AC troubles
Ok...my buddy came over and looked it over. I guess when the temp control is in the defrost position, it causes the compressor to cycle. Im not sure if it stops after the truck warms up yet...but i will check it out on a cool day.
Old Apr 26, 2011 | 08:27 AM
chrisbmo2000's Avatar
This is normal and will continue to do it. it is something that GM and Ford and some others did to help with defrost and to keep the oil moving in the compressor so it doesnt lock up....it all came about shortly after the 1 belt for every thing idea.....................
taz
Feb 18, 2009 12:00 PM
Liv2hunt
Feb 8, 2009 04:29 PM
munter
Oct 13, 2008 05:54 AM
Rhyse62
Sep 17, 2008 03:56 AM
gmight
Jul 27, 2006 11:24 AM
