Air Conditioner Cycle Switch
Old Apr 7, 2008 | 02:10 PM
sking2127's Avatar
Default Air Conditioner Cycle Switch
The A/C Compressor does not stay engaged on my 2000 Z71, 5.3L, V8. When the compressor is running the A/C is Ice Cold, however it will eventually turn to blowing outside temperature air (which in Alabama in August is not pleasant). If I push the A/C button in the cab to turn the A/C off, wait a few moments and then turn it on again, the air again is ice cold. I've done this while the truck is idle and when I push the A/C button you can hear the compressor clutch engage. This led me to beleive that for some reason it's disengaging when it shouldn't be. A buddy that has a Tahoe suggested the switch on the side of the accumulator (A/C Cycle switch or high pressure cutoff switch?)is a relatively easy and cheap fix that may solve the problem.
Anyone have any experience with this and/or know what the switch is called?
Old Apr 7, 2008 | 02:16 PM
Argon's Avatar
Default RE: Air Conditioner Cycle Switch
its a cycling switch...or low pressure cut-off switch....pretty good bet thats the problem...COULD be a weak compressor clutch
Old Apr 7, 2008 | 02:22 PM
jcbst12's Avatar
Is it possible it could just be on the border line of being too low on R-134A to allow the compressor to stay on?
Old Apr 7, 2008 | 02:50 PM
Argon's Avatar
DOUBTFUL IF IT GETS ICE COLD WHEN ITS ON...its most likely the switch..but..as usual..she needs to be checked to know fer shore
Old Apr 7, 2008 | 02:54 PM
sking2127's Avatar
Thanks, I'll give it a shot!
Old Dec 30, 2009 | 08:57 PM
goldenhammer's Avatar
Would lack of refrigerant cause the compressor to NOT engage? I had similiar problem except no AC engagement at all. Replaced the AC cycling switch still nothing. But i can run a jumper directly from the battery to the AC compressor and it does engage.
Old Dec 30, 2009 | 08:59 PM
Did replacing the AC cycling switch solve the problem?
jwad10
15
May 14, 2010 10:42 AM
martyn
Jun 30, 2008 09:41 PM
chevytillidie24
Aug 11, 2007 11:26 PM
gmight
Jul 27, 2006 11:24 AM
Bert
Jun 1, 2006 11:17 AM
